Ted Lee
- May 8, 2001
hi all -
as some of you may (or may not) know, i've decided to build my own pc. i've decided on my mb: Asus P4B533-E
now i need a box to put it in. i'll probably just go to fry's or something for this.
the only thing i'm aware of is that the case needs to fit a special rear i/o shield? from motherboards.org:
The P4B533-E is a modified ATX standard motherboard that sizes in at 12 inches by 9.6 inches or for you metric minded 30.5CM by 24.5CM. This board should fit in any standard case that accepts the included modified rear I/O shield.so, besides that caveat, is there anything special i should think about when picking up a case? also, i assume a minimum of 300w for the power supply? i guess more power couldn't hurt though?
so, what features should i look for and what's a reasonable amount to pay?
thanks,
ted
