Bought a 100' spool of 14g in-wall speaker wire from partsexpress. I was planning on using this for bi-amping my speakers (currently bi-amped with Monster XP wire).
With the revamp of the room, the lengths are going to be much longer and MXP is too expensive, thus the PE wire.
Noted on the jacket, "unsheilded". I did not, nor ever consider weather or not speaker wire was shielded. I've pretty much always used Monster speaker wire and no where does is say, on the wire or their website, if their wire is sheilded.
Should I be concerned?
Should I return my spool and buy other wire?
If so, any recommendations...on the cheap?
Peace Out~
Peace Out~
