4 days I think he saidI meant to ask Dave if he lost power. A week?
Thanks for the podcast guys, and thanks @Dave Upton for the info. I definitely want to delve into REW, but I don't have a notebook computer. Fortunately, I am tempted by the new M1 MacBook Air. do you have specific recommendations of a reasonable microphone?
So, are you saying that the Sonex that I have in my HT for first reflections don't actually do much good? Or were you saying more that they're not effective with sub frequencies? Is that approach simply not effective for general deadening of the room, as opposed to for bass traps?
Just thinking of economy. For treating first reflections and general brightness, isn't the foam going to be effective? That's really in frequencies over 400Hz, isn't it? I also want to explore bass improvements, but in my room it's more the brightness I want to tame. I definitely want to analyze any bass problems, but I seem to have been able to mostly alleviate them with placement.The egg crate type foams are just not as effective as other products. If you look at test results, you’ll see they’re most effective in the 3-400Hz range and up. They’ll do next to nothing for bass.
Bass traps generally have to be at least 4” thick, ideally 6 or more .
Here are some examples. Here’s your egg crate type foam:
Now for comparison here is a standard 2 inch panel from gik acoustics:
Now compare these to a corner bass trap:
And a monster bass trap in panel form:
As the data shows, the egg crate is better than nothing, but it’s effectively useless for treating the most problematic and important frequency range in most rooms.
I am not advocating for treating only the bass frequency range, but the panels that do effectively treat bass will also have a positive impact on the mid range and high frequency problems in your room.
Now that panels are on the market with what they call flex range technology, you can get all the benefits of a bass trap with some Diffusion, ultimately preventing your stereo image from collapsing.
I have a combination of monster bass traps, corner bass traps and wall panels in my room, in addition to a couple of specialized MSR acoustics spring traps narrowly targeting the 60 Hz region which is problematic in my room.
I fully agree. This has also been a learning experience for me through the years. The biggest benefit I found with my speakers was when it was suggested they be moved away from the front wall. So, now their backs are 4' from the wall, and further from the side walls, and there are no windows. So it's really not a reflective as most rooms. Also, as I've been able to get better electronics, the supposed "brightness" of my Thiels has completely disappeared. They are now revealing and resolving, rather than bright. Now that I think about it, I can't remember the last time I thought they were harsh sounding. Honestly, this new amp (which I was extremely hesitant to buy) has made the most significant difference any single component has ever made to the system. Every other amp I've ever used with the Thiels seemed out of control by comparison. I don't know what the difference is due to. It has to be more than just power. It just feels and sounds like it is in total control of them, for the first time.Generally speaking, perceived brightness is not only the result of an acoustic problem. It is a problem that starts with the way your system is put together and the actual components of said system, followed by the placement of your speakers and listening position, and finally amplified or tamed by acoustic treatments or the lack thereof.
I’ll just be waiting for an M1 MacBook Air refurb.I have the Umik combo which is the go to for REW noobs like me
The good news is you can run REW on any computer - so at least it's not picky.I’ll just be waiting for an M1 MacBook Air refurb.
They are up on Apple.com now $809I’ll just be waiting for an M1 MacBook Air refurb.
I keep telling you, those are Intel models, not M1.They are up on Apple.com now $809
They had em. Must be gone nowI keep telling you, those are Intel models, not M1.
Thanks Dave. I ordered the Microphone and the Verified+ meter. I only have the legendary (notorious?) old analog RatShack model. I'm guessing if I want to EQ my subs, I would then use something like THIS?The good news is you can run REW on any computer - so at least it's not picky.
Regarding microphones, I generally also recommend the UMIK-1 or newer UMIK-2, but there are a few other good options like the Dayton UMM-6 or a calibrated mic from Cross Spectrum Labs.
Here's the Dayton: https://www.parts-express.com/Dayton-Audio-UMM-6-USB-Measurement-Microphone-390-808
Cross Spectrum buys mics from MiniDSP and runs a more advanced calibration on them. Worth the extra expense if you plan to buy for life:
Cross·Spectrum - Calibrated MiniDSP UMIK-1 Microphones for Sale
Purchase calibrated MiniDSP UMIK-1 measurement microphones, low-cost option for performing precise and accurate sound measurementscross-spectrum.com
Cross Spectrum also sells my reference SPL meter, a tool that every home theater enthusiast should invest in. The Galaxy CM140 SPL meter.
Cross·Spectrum - Galaxy CM-140 Sound Level Meter
Purchase calibrated Galaxy CM-140 Sound Level Meterwww.cross-spectrum.com
Yeah, I use my HTPC to run REW and other calibration software.Thanks Dave. I ordered the Microphone and the Verified+ meter. I only have the legendary (notorious?) old analog RatShack model. I'm guessing if I want to EQ my subs, I would then use something like THIS?
I have recently upgraded four mac Minis and realize I can just set one of the old ones up with a monitor in the HT to run REW.
