I'm not sure what you mean by "the regular way", but using ARC is fine as long as it works. If it doesn't you'll need an optical from the TV to your receiver. This is all assuming that you have an OTA antenna or are using aps on the TV; otherwise, you probably don't need the ARC and any HDMI port will do.
When I said regular way I was meaning the way you would usually hook up audio/video without arc cable. Just wondering if would make a difference either way.
ARC is ONLY for eliminating an audio cable between the TV and receiver when you use the TV's internal tuner or apps. You never use it for anything else. All your other sources, such as blu-ray player are connected directly to the receiver using hdmi, then video is passed on to the TV.
