seth_petry_john
- Oct 12, 2003
When I move into my new house in 3 weeks I intend on flush-mounting my 57" Toshiba 57H82 into a wall in the finished basement. The wall is already built, along with enough space behind it to fit the set into, so all I have to do is cut a big hole and then push the set through.
However, I REALLY want to cover up the speakers in the TV's base, leaving just the screen visible. I intend on running all audio through the receiver and external speakers.
So here's my problem: the screen sticks out in front of the base maybe 1/2" on the sides, but only ~1/4" in the center... the base curves outward a little in the middle. Therefore, I can't just patch the drywall once the TV is set because I don't have enough depth.
I thought about taking some plywood or paneling and attaching it to either side of the opening in the drywall and then painting over it, but my fiance thinks the paint will look different when applied to wood than drywall.
So here's the point: what sort of treatment can I apply to the wood so that, when painted, it will look just like painted drywall? Is there any kind of plaster compound that will work? Can I putty over the entire length of wood and then paint?
Any suggestions would be VERY much appreciated.
Seth
Seth
