Component vs. svideo (1 Viewer)
I just pretty much finished setting up my HT (yay). Lots of tweaking still to do though. Right now, the DVD player is hooked up to the receiver via svideo. The receiver upconverts to component for the projector. I'm thinking it would be a very good idea to connect the DVD player to the receiver with component instead. Is it likely that this will result in any noticable quality difference?
Stacey
Hi James.
I'm thinking the best quality picture would be to hook the Composite (the Yb, Yr, Pb) directly from your DVD to your Projector.
If this is an impossibility, then Composite from DVD to Receceiver then from Receiver to Projector.
If your Receiver does not support Composite in/out, then the S Video is the next best signal followed lastly by Component (right, left, video).
Hope this helps.
Leo Kerr
um, minor correction here...
COMPOSITE: the single coax connection, often coded 'yellow' and is just one step above an RF connection.
COMPONENT: the three coax connection, often coded red-blue-green, and marked Y-Pr-Pb.
Leo
Yep, I'm talking component, not composite. From what I was reading last night as well, I might eventually end up going with a DVI connection, but in the meantime, I'll stick to component where possible. DVI will require a new DVD player and a new cable run, so that may have to wait.
Stacey
:b
Whoopsie, I should know better than to post at 6am.
Component + composite + 6am + awake 12 hrs straight = one confused canuck :D
Allan Jayne
When the receiver upconverts the S-video sources to component, it is still much better to connect a DVD player using component in the first place.
The video as taken off the DVD itself is componetn video. To use its S-video output jack the DVD player converts that into S-video which is extra circuitry there too.
Video hints:
Thanks Allan. I picked up a component cable for the DVD -> Receiver, and it definitely looks better. My next step is to buy a DVD player with DVI out instead, and run it straight to the projector. That all depends on the budget though :)
Jquick80
