Geoff L
- Dec 9, 2000
- Geoff
I finally broke my last hole saw building a big ass sub for my brothers garage.
Who makes a drill based hole saw thats adjustable from say 1" to 4"'s and is a tuff little mother?
Cutting out circles in 3/4" MDF braces seems the fastest using a hole saw but is tuff on them. The best one I've used so far was a Black & Decker, belive it or not.
Uses a drill bit for the start of the hole and is depth adjustable. Also the size of your cut out hole itself can be adjusted ~{and this is what I'm looking for}~!!!!
The 3 cutting teeth on the BD hole saw stayed sharp for a long time. It had a set of three v-type teeth that could be filed sharp again if needed. Never had to sharpen them even after cutting probably 70-plus easy three inch 3/4" MDF holes in braces. This one would only open to cut a 3.25" hole tho and shrink down to cut as small as 1" hole.
I went back to where I bought this one 2-3 years ago, and they "didn't" have that one anymore, nor one that was similar.
I much prefered it to using the router due to much less flying dust and it was just plain "allot faster and cut just as clean".
So what are you using that is ~{hole size adjustable out to at last 3"-min}~, 4" or larger hole would be nice but needs to adjust down also in hole size cut out. Nees to cut clean and no problems getting the piece cut out off the cut out saw. Also that you think works well and lasts, "if it's pricey"???
A link to the product/hole saw would be nice if possible, & or, where to find it store wise. Lowes/HD/Ace/Etc...
Thanks much
Geoff
Thanks much
Geoff
