Which is easier to understand? (1 Viewer)
John*DB
Which is less "techy" and user friendly?
DVE or Avia?
I am assuming they will accomplish the same thing. Probably everyone has their favorite but the end result (I am guessing) will be the same.
Is one easier to grasp - step by step
What I really need is DVE for Dummies...anyone have that DVD?
Paul-D
I have used Avia. It's very good and very user friendly. It explains everything step-by-step, then allows you to do it on your system.
Very nice!
ChrisWiggles
I own both, and another vote for Avia for overall use. I use it almost always, I only purchased DVE for a specific technical attribute that unfortunately was not able to be included on the original consumer Avia. Avia covers pretty much all, and is easier to navigate.
andriesprice
