Raptor382
- May 23, 2011
- Sam
Looking to make some upgrades.
Currently have:
Yamaha RX-v871
Outlaw audio LFM1+
Infinity P363 (mains)
Infinity PC351 (center)
Infinity P163 (surrounds)
The Infinity speakers are a bit warm for me. They seem to not have good mid range to upper range. I like my speakers to be a bit more vivid than that. Perhaps I need to find a speaker that is a bit brighter? I used to have a pair of Paradigm monitor 9's that I remember that I liked.
I was thinking of just upgrading speakers, but now, i'm wondering if maybe I just need to put more power to them. Outlaw audio sells their model 2200 amps which are 200W each. If I were to buy a pair of them for my mains, then later get amps for my surrounds and center, would that make a significant difference in the way the Infinities sound, or would I end up just spending money and be disappointed? Eventually, i'd work on getting amps for all my speakers, then changing out the Yamaha for an Outlaw Audio 975 pre/pro, but, if the AVR isnt the problem, i may stick with that and just work on speakers first.
Im not able to spend a lot at once, so I plan on upgrading a little at a time. Right now, I have about $1000 to start with. In your opinion, would I be better just keeping the speakers i have and giving them more power or would it be best to upgrade the speakers first, then add amps and a pre/pro later?
If speakers, what would you recommend in my price range? $1000 for a pair of front main speakers.
Ive been looking at:
Klipsch RF82 II
B&W 684B
Polk TSX440
Polk TSX550
Polk RTiA7
Maybe there is another brand that would be equal or better than what I listed that would be within the same price range?
Anyway, just wondering what you think the best upgrade path would be. Speakers first, or amps first.
Thanks, your replies would be helpful.
Currently have:
Yamaha RX-v871
Outlaw audio LFM1+
Klipsch RF82 II
B&W 684B
Polk TSX440
Polk TSX550
Polk RTiA7
