RyanYYZ
- Sep 16, 2004
Periodically my speakers are popping - it seems to be mostly coming from the rears.
It seems that when something is turned on or off on the circuit the speakers will pop.
- I HAVE all of the components on a surge protector
- I DON'T HAVE more than one power bar plugged in (daisy chained etc.)
- I DON'T HAVE any extra splitters (ie a six-way out etc.) in the mix for the stereo equipment.
My suspicion is the issue is coming from a power line somewhere along the speaker run. For the rear speakers I ran the cables straight down the inside of the wall to a hole near the floor and then back out and along the baseboard. Could there be a line in the wall that they're crossing or something?
Trouble shooting suggestions?
Remedy suggestions?
Ryan Coleman
Remedy suggestions?
Ryan Coleman
