johnnyFTWedge
Grip
- May 30, 2013
- Justin
So I ended up putting all 3 front speakers above the screen. I have to say I couldn't be happier with the decision. The bottom of each speaker is about 2" above the top of the screen. After using the Audyssey setup mic that came with the Dennon X1000, the sound is crisp and seems to come from the screen. I haven't had any issues with sound seeming to come from above the screen.
As far as image quality goes, I also couldn't be happier. My throw distance ended up being right at 13'. When I first fired up the projector it was midday with a good amount of sunlight in the room. There was a noticeable hot spot in the top middle part of the screen. After putting about 22 hours on the Epson, I calibrated it using the Disney WOW disc in 3 different lighting conditions (Day, Night with lights, Night no lights). The hot spot has all but disappeared.
I've watched several NBA and NFL games and a few blurays, and the image quality is stunning. I've tried all the various color modes and find THX at lowest lamp setting perfect for my environment.
The only slight hiccup I've come across so far is in very bright scenes, sometimes you can see the texture of the black diamond screen. It's a minor gripe and other than that I couldn't be more pleased.
I will try to post some pics later.
