johnnyFTWedge
Grip
- May 30, 2013
- Justin
So I finally did it! I went out and bought the following:
Projector: Epson 5030UB
Screen: BD Zero Edge 100" 1.4 gain
Receiver: Denon X1000
Speakers: Sonance VP62 in-wall
I need help choosing where to place LCR speakers. Screen is 88" wide and going on a 92" wide wall. Obviously there is no room to put LR speakers to the side of screen.
My two options are to put all 3 LCRs above or below screen. VP62s have a pivoting tweeter so at least I have the flexibility to have sound directed at the viewer.
Aesthetically I like the way speakers look below screen but I've read above screen may produce better performance. Although there doesn't seem to be a consensus.
My ceilings are 9' and screen is 49.8" tall. With seated eye level at 48", to have eyes 1/3 the way up screen, bottom of screen would be at 31.4" and top at 81.2". This leaves me 26.8" above screen and 31.4" below screen. Speakers are 12.25" tall.
There will only be one row of seats so sound coming from below screen being blocked won't be an issue.
I've attached some pics of the room to help visualize the set up. Screen will be going on wall behind TV on floor.
Any suggestions would be greatly appreciated.
