John DeSantis
- Nov 18, 1999
I just got this Unit. It was recommended to work well with my Infocus 4805. My first impression is that it is no better, and may be a bit worse, than my $57.00 Toshiba.
I could not get a correct aspect ratio using the M1 to Component connection. I tried every setting and read the manual twice. The player was set for WIDE and made sure the PJ was in 16X9 mode. The bottom of the image was just cut off. Tried all the output settings..480P, 720, 1080i, etc.
So, used the S-VID to the PJ. AR was OK but image was a bit dark. There are settings for this in the Player but didn't need it before. Very dissappointed. The reviews were pretty good for this Player but it just doesn't seem to work well with my setup.
So, I may try it with a TV but really can't see any reason to keep it.
http://oppodigital.com/
