I am looking to *possibly* add two overhead ceiling speakers to my basement home theater so that I may enjoy Atmos sound.
I have a couple stupid questions to ask. I say "stupid" because I know nothing about the best way to go about all of this. I am depending on some knowledgeable answers from the membership.
1. I have Atlantic Technology speakers throughout my 7.1 setup. Should the two overhead speakers I am looking to install also be from that company?
2. I have a drop ceiling in the basement. The acoustic "tiles" are very soft. Almost felt like. They cannot support speakers. I also don't have the skill to hang speakers from the ceiling above it by chain. Should I buy black solid tile panels to mount speaker enclosures into? If so, can you recommend a brand?
Have another idea if possible....
3. Is there such a thing as pre-made speaker tiles? By this, I mean you buy a drop-ceiling tile with the speaker enclosure already built into it so that you simply connect the wiring and slide the panel into place?
I plan to put both speakers directly over my seating, which consists of two chairs side-by-side. I am guessing that would be the proper arrangement.
Thanks, in advance, for your assistance.
