Hi all,
I'm trying to upgrade my 5.1 setup to a 5.1.2 setup. I'm new to Atmos (and no sound expert in general) so excuse my ignorance
The room I have doesn't allow for in-ceiling speakers, nor on-ceiling from the side as I usually see in Atmos setups online because it's a open room. It just wouldn't fit.
I was planning to add 2 Atmos height speakers that have a slight output angle downwards (21degrees)
I was wondering what would be the best distance between the listening area and the speakers? Can I place them as high as possible above the front speakers (which fits best), or is it better to move them closer to the listening area?
Distance between listening area and front speakers = 220cm (7.2ft)
Ceiling height = 260cm (8.5ft)
Thanks a lot for any advice
