steve mm
- Feb 26, 2002
i have a box that is (out side dim)22x21.25x21.25 i think this would be 5 cub feet?internal.specs are fs 28,re(ohm)3.7, le(mh)3.3, qms 6.20, qes 0.52, qts 0.48, vas (cuft) 4.23, vas (liter) 120, power watts rms 200, power peak 400, spl db@1w1m 89, xmax inches 0.31, xmax mm 8, speaker displace cu ft 0.09 there are 2 12 inch drivers in the box could some one please run the numbers and see what i can do thank you
