Jeff Bayne
- Jan 17, 2003
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-428
Hey guys, I have a set of old Altec dome tweeters, and crossovers (1500hz) and I'd like to make some bookshelfs or towers with these woofers. looking for tight, accurate sound. They'll actually be used as if they are studio monitors. I have a rack amp to power them. I'd also prefer to do sealed. Can you please plug in the perameters and give me an optimum volume?
Specifications: *Power handling: 65 watts RMS/90 watts max *VCdia: 1-1/2" *Le: 1.07 mH *Impedance: 8 ohms *Re: 7.58 ohms *Frequency range: 40-5,000 Hz *Fs: 52 Hz *SPL: 85 dB 1W/1m *Vas: .76 cu. ft. *Qms: 4.77 *Qes: 1.45 *Qts: 1.11 *Xmax: 3 mm *Dimensions: A: 8", B: 7-5/16", C: 3-7/16".
Thanks a ton!
jeff
Thanks a ton!
jeff
