EricWT
Grip
- Mar 19, 2002
Hello,
I just connected my circuits to my breaker panel, and everything seems to work fine. There is a buzz from my dimmed lights, but I have cheap bulbs in there now and I understand that this is normal; I will replace them soon.
However, I noticed that there is also a buzz from the circuit panel-- I can hear it when I stand near the panel, but when I put my wooden cover over it, it goes away. The buzz is there whether the lights are dimmed or at full brightness, and gone when they are off. Is it possible that the buzz at the lights is causing some noise at the panel, or is it more likely that I have a breaker problem? None of my other circuits seem to buzz; then again, none of them has a dimmer on it. I am worried that I did something wrong, although I can't imagine what it would be.
My components in this circuit are:
5 sconces with cheap 60 w bulbs (will replace)
4 wall plugs
1 Lutron Spacer remote controlled dimmer
Sqaure D panel with a 15A breaker
(I wired a separate, dedicated 20A circuit for my components)
I wired it with 14/2 NMD 90 to the panel, and 14/3 throughout the circuit.
Eric
4 wall plugs
Eric
