Carson E
- Aug 5, 2001
Hello to all:
I was wondering if someone could confirm a solution to using "dimmer type switches"
In my new HT room I want a couple wall lights on each of the long walls. 15X27. And maybe in ceiling. These will use a dimmer switch, but I have been told that noise leaks will probable be a problem. (Spk. buzzing etc.)
The solution ( other than using as high quality switch that my budget will allow) is to split the electrical panel box by using one side for a separate 20amp breaker for all wall plugs in the room that components will use. And use the other side of panel for the lights especially wall light switch using the dimmer.
If anyone could offer an opinion on this and one on a dimmer (reasonable cost) to use I would most appreciate it.
Carson E
Carson E
