Tim_Wetzel
- Dec 26, 2001
My girlfriend has a component receiver in a small built-in cabinet in her living room. It's connected to speakers that are installed in the ceiling in several rooms. This was all installed when the house was built, and it wasn't done very well. The FM antenna was just a short piece of coax that was jammed into the jack on the receiver, which I have since remedied. The AM antenna was a piece of cat5 with two of the wires stripped and inserted into the "AM Loop" jacks on the receiver. AM reception is slim to none at the moment, and she is trying to pick up fairly local channels.
A google search shows WAY more info on AM antennae than I care to know about. She wants to avoid any type of antenna that has to sit out in view (the cabinet in a fairly non-discrete location in the room) and there is not much room inside the cabinet itself.
Is there a "better than nothing" type of DIY antenna I can install that will hopefully at least pick up local stations?
