Matt300ZXT
- Nov 27, 2009
- Matt
My dad purchased a Denon home theater in a box from Best Buy with the Boston Acoustics speakers. It's the DHT590BA system. It has HDMI ins, component, composite, Svideo, all sorts of stuff. Here's what I need help with, I need to know the optimal way to run this system with the various items that make up the home theater, so this will work as best as it can.
http://www.usa.denon.com/ProductDetails/5021.asp?ProductName=DHT%2D590BA%3A+A%2FV+Receiver+%26amp%3B+5%2E1+Speaker+Package#
That will take you to pictures of the receiver to see how the unit it setup.
Anyways, here's what we've got.
JVC 57" rear projection HDTV
LG upscaling DVD player with HDMI out and Optical out
Motorola Comcast cable receiver with HDMI out
old record player (that one's easy to figure out, red and white cable plugged into the receiver)
What we did was run an HDMI cable from the DVD player into the tv for video and sound through tv speakers, then ran an optical cable from the DVD player to the receiver for audio only. Unfortunately, the DVD source on the receiver will not let you assign Optical as a source of sound, only HDMI. So since it's not hooked in to DVD, we don't have access to all the built in DSP settings for different types of movies. I had to use the DVR source as it allows you to use Optical as an audio source.
Next we hooked the Comcast receiver straight to the tv with an HDMI cable, and tried hooking an optical wire from the tv to the back of the receiver so we could watch tv movies through the surround sound, however it is not working at all through the receiver. This receiver isn't as easily programmable and assignable as mine is.
I guess my question is, what is the optimal way to set this system up? I've never sent video signals through my receiver, then on to the tv like can be done, so I don't know the benefits of doing it that way. If you guys can suggest some setups for me, I'd really appreciate it.
