Rob.Bar...
- Sep 13, 2004
I am working on my home theater room, and was trying to figure out where to put my subs. I am going to be using adire shiva's, and the best winisd plots all look for > 5 cubic feet. Well, its seems the rear sofa riser is basically a big box right...
So my idea is to build two boxes that are 10" high, 36" wide, and 5' deep. The front would slope out at a 30 degree angle or so to give me enough room to mount the sub. On top of the two boxes build the rest of the stage with a few sheets of ply and you are off to the races.
Are there any glaring problems with a design of this nature, other than you need grills to keep people from kicking your subs in?
-Rob
-Rob
