Erek_S
- Jul 9, 2004
I am wiring my theater's subs, and wanted to know if I can use a 12ga. speaker wire for the long run to the wall jack (inside the walls, and ceiling) or if I need to use a regular shielded sub cable. Is there any differance? I am running two Klipsch sub's, one 15" and one 10". The first run is about 45 feet to the wall plate, and the second is about 28 feet. I want to make sure that I dont lose too much from the wire, once its in I'm unabe to change it.
Thanks Troy
Thanks Troy
