BrunoB
- Sep 6, 2002
I found a neat trick on my 4ES. Rotate the jog dial while playing a DVD: it gives the bitstrream data rate, e.g 400 Kps for Dolby Digital or 1536 kps for some DTS movies.
I found a neat trick on my 4ES. Rotate the jog dial while playing a DVD: it gives the bitstrream data rate, e.g 400 Kps for Dolby Digital or 1536 kps for some DTS movies.The firmware revision is at the very end of that data.
Seth
I was reading the manual and it talks about 2 way remote control system. What is that used for?Some Sony receivers, such as last year's 5ES, and most of the ES receivers in the last few years previous, included a 2-way remote control system. The remote could receive signals from the receiver in addtion to sending commands. This 2-way communication was used to provide certain types of feedback to the remote, including disc and track names of the song playing in a Sony CD player, names of radio stations, names of the inputs, etc. It was a very slick system, and some people loved it; others hated it. There was a delay in using most commands from the remote, because the remote and receiver had to communicate back and forth. It is becoming less common now, and now only the 7ES (in the ES line) has a 2-way remote. I'm not sure, but the volume setting may have been displayed on the remote.
I will be using a 2-way touchscreen remote (RM-TP504) from a slightly older reciever with my 4ES. My receiver and all other components are located at the back of the room, so I can't see their displays at all. The only issue with an older remote like this is that it does not have controls for certain newer functions, like 6.1 decoding and DPL-II and dts NEO:6. Luckily, this one has learning capabilities.
Although the 4ES has the capability of using a 2-way remote, Sony included a standard 1-way remote. This is likely for two reasons: 1. cost savings, and 2. due to negative feedback from some of the users of 2-ways in the past.
