I was trying to find out that do PA speakers like PEAVEY PVX 12 sound better than home theater tower speakers. I was planning to upgrade my satellite front speakers with passive full size speakers. Please help me figure it out.
$450 for a pair of fronts.
@ArmSC I am in India and speaker size is not an issue. Quality is more important.
PA speakers have different design priorities than home speakers. They have to be build tough enough to bounce around in the back of a van going from one gig to the next, and they have to be able to play for hours on end at ear splitting levels, gig after gig, year in and year out, as well as outdoors in heat, cold and humidity.
On top of that, PA speakers are not designed to sound their best at a distance of 8-15 ft., as is the situation for home listening.
Way down the list of priorities is sound quality. PA speakers that sound good enough to be in a residential hi-fi installation are few and far between, and the ones that do will cost you many times more than a home speaker that sounds as good as it does.
If $500 is your budget, there is no shortage of offerings from SVS, Axiom, Hsu, Paradigm et. al. that will sound better.
Wayne A. Pflughaupt
