Buying directly from Oppo is the best way to go IMO. Why get a middleman involved?
Unless you can get a price break from somebody like Value Electronics.Buying directly from Oppo is the best way to go IMO. Why get a middleman involved?
Last week, I bought that Region Free Mod Kit for my Oppo 203 and it works perfectly. I then placed my Region Free Modified Oppo 103 into my Bedroom HT and moved my Region Free Oppo 93 into my Computer Room HT.So glad I read this before buying (and so glad I waited till Christmas season to buy).
I don’t think Oppo’s are discounted. Oppo itself may have refurbished models for a discount. I’m thinking I bought my 203 via Amazon, but the seller was Oppo.Next question, can anyone on HTF recommend a vendor to purchase a zippo UDP-203, I mean an Oppo UDP-203?
Cursed auto-correct!'
Why does holding off the purchase mean more points. Isn’t it the same points whenever you buy? Are you sure the price break will be good until then?Bombay Electronics seems to be offering me a price break on the region-free modification. Right now I'm looking at a price of $591 including the region-free mods (normal price is $699 still listed officially). Maybe that conversion kit is having an effect on the market. Or maybe its the military-vets discount.
Holding off till Dec 8th (credit card cycle (more points) and also closer to Christmas. Also for warranty period reasons). Money is put away for this but my credit card point total almost covers the purchase entirely.
Wife is getting a nice new laptop at the same time.
Next year is the year for the new 75" UHD-4K TV (with HDRxx and DV). Looking hard at Vizio M 75.
That's an audio track. Select audio on your remote and you can access them that way. They probably won't be labeled as commentaries, but they should be there.I can't seem to get at the commentary tracks on Game of Thrones Series 6 Blu Ray - any ideas?
You're not getting much response to your question. I'd suggest making it a separate thread.Sorry. I should have been clearer. The audio button on the remote doesn't reveal the tracks (often Dolby 2.0). The on-screen menu can be selected as 'on' but it doesn't work. I guess its something to do with my Oppo's audio output settings. I'll have a play around, but if anyone has anything definitive...
I’ve found that setting the audio to ‘secondary audio on’ on the Oppo allows me to chose ‘play with commentary’ from the disc’s menu. Having just read the review of series 7, it might have the same issue and I have yet to see what impact this Oppo choice has on other audio playback. As Todd says in his review, the discs could have been authored better...I don't have an Oppo, but sometimes this issue has to do with the BD Audio Mix setting. You may want to play with that.
