Oppo Releases UDP-203 4K Ultra HD Blu-ray Player
Discussion in 'Playback Devices' started by Dave Upton, Dec 12, 2016.
Tags:
  1. dpippel
    dpippel HTF Premium Member
    Feb 24, 2000
    5,767
    2,069
    9,110
    Yoyodyne Propulsion Systems
    Doug
    You're right. I was thinking that the the 6/6 release was a public beta.
  2. Sam Posten
    Sam Posten Moderator
    Oct 30, 1997
    22,763
    2,551
    9,110
    Aberdeen, MD & Navesink, NJ
    Sam Posten
    I got a firmware update this AM, was I behind schedule or was this something new?
  3. dpippel
    Feb 24, 2000
    5,767
    2,069
    9,110
    Doug
    It's just you Sam. ;) The last firmware release was on 6/26.
  4. Sam Posten
    Oct 30, 1997
    22,763
    2,551
    9,110
    Sam Posten
    Weird. I bought my deck after that and did the firmware upgrade on day 1...
  5. Robert Crawford
    Robert Crawford Moderator
    34,170
    9,085
    9,110
    Sam,
    I just did a firmware update on my player today and I already did an earlier Beta firmware update in early June.
    Sam Posten likes this.
  6. Johnny Angell
    Johnny Angell Played With Dinosaurs Member
    Dec 13, 1998
    8,510
    1,940
    9,110
    Central Arkansas
    Johnny Angell
    Don't you have to have no disc in the player to do the upgrade?
  7. gadgtfreek
    gadgtfreek Supporting Actor
    Oct 13, 2014
    694
    288
    610
    Jason
    Well, Im back with the Oppo, hopefully this go around is better than the release model I had. I am going Dolby Vision and it is the only game in town IMO (not buying the LG player).
    Checked out some POwer Rangers, looks pretty dang good and makes sense in how I have found out Dolby and LG are handling the DV modes on the OLEDs.
  8. Robert Crawford
    34,170
    9,085
    9,110
    Man, you change HT equipment like some people change their underwear.
  9. gadgtfreek
    Oct 13, 2014
    694
    288
    610
    Jason
    LOL, why do you think I have the screen name I do!
    I still have the X800 and UB900, but if I am going to start mucking around with Dolby Vision I have to have the 203. Ill prob sell the 900. Also glad I grabbed a A3060 Yamaha, supposed to get a DV update.
  10. Colin Jacobson
    Colin Jacobson Lead Actor
    Apr 19, 2000
    6,760
    1,182
    9,110
    Once a year, whether it needs changing or not?
  11. Steve_Pannell
    Steve_Pannell Supporting Actor
    Feb 4, 2003
    704
    73
    610
    New Albany, MS
    Steve
    I know this post is a few months old but I'm thinking about buying the UDP-203 and I have a question:
    After installing the region-free kit and you want to watch a region "B" Blu-ray you do the keypress sequence on the remote. I understand that. But, if you want to watch a region "A" Blu-ray do you have to do the keypresses again? (Inputting a different code, of course)
    Also, I think I read that the kit makes the player region free for DVDs by default. Is this correct?
    Thanks, from a region-free newbie.
  12. dpippel
    Feb 24, 2000
    5,767
    2,069
    9,110
    Doug
    Steve - Yes, the Blu-ray region change is sticky, so if you set the player to Region B you'll need to reset it to Region A when you're done. Also, I believe you're correct about DVD region functionality, but I've never used it so don't know for sure.
    Steve_Pannell likes this.
  13. SAhmed
    SAhmed Supporting Actor
    Jul 10, 2005
    603
    317
    610
    Noblesville, Indiana
    Shakeel
    The kit does make the player region free for DVDs. You can specifically set to a particular dvd region should you want to.
    Znook and Steve_Pannell like this.
  14. ManW_TheUncool
    ManW_TheUncool Producer
    Aug 18, 2001
    6,030
    43
    6,610
    The BK
    ManW
    Depending on your actual collection, etc, you might also find you can often leave it set to some other region for a number of subsequent viewings because many discs released here (and in other regions) are actually all-region. So I usually don't switch back until I actually need to.
    The region switching process can be a bit annoying, but programming some universal remote macros to do it for you helps a lot.
    _Man_
    Znook likes this.
  15. dpippel
    Feb 24, 2000
    5,767
    2,069
    9,110
    Doug
    Yep, I have my URC programmed with a one-button press for all three Blu-Ray regions. Easy peasy.
    Znook likes this.
  16. Steve_Pannell
    Feb 4, 2003
    704
    73
    610
    New Albany, MS
    Steve
    One more question, if y'all don't mind:
    Does this player "upscale" standard DVDs as good as the Oppo players I've heard about in the past?
    The reason I ask, I have a Toshiba HD-XA2 HD DVD player that does a very good job with standard DVDs and if this Oppo player does as good or better I'd like to have just one player to do everything--DVDs, Blu-rays, etc.
  17. dpippel
    Feb 24, 2000
    5,767
    2,069
    9,110
    Doug
    As far as 4K uHD players go, the UDP-203 is (IMO) a best-in-class upscaler for 480i/p material. I've yet to find anything that beats it. The Sony UBP-X800 comes close, but the Oppo is still on the top of the heap.
  18. Scott Merryfield
    Dec 16, 1998
    12,999
    1,478
    9,110
    Keep in mind that if you have a 4K display, using your HD-DVD player to upscale DVD's will involve a two-step upscaling process -- the HD-DVD player going from 480i/p -> 1080p, and then your display going from 1080p -> 2160p. That's a lot of processing of the video signal. Using the Oppo (or Sony X800, as I do) keeps this as a single process from 480i/p -> 2160p. Of course, if your display does a good job of upscaling, you could let it handle the entire process from 480i/p -> 2160p.
  19. Steve_Pannell
    Feb 4, 2003
    704
    73
    610
    New Albany, MS
    Steve
    Thanks, Scott.
    I'm probably going to go with the Oppo. I don't have a 4K display yet but I think the Oppo would be a good first step. I'm just trying to trim down the number of components in my system. The Blu-ray player I have now does OK with Blu-rays but not very well with DVDs. That's really the only reason I've still got the HD-DVD player.
  20. Scott Merryfield
    Dec 16, 1998
    12,999
    1,478
    9,110
    I kept my Oppo 980H DVD player for the same reason, Steve. My Panasonic BD player does a poor job with DVD playback, and the Oppo also handles SACD and DVD-audio formats. When I got the Sony X-800 UHD player, though, it did an excellent job of upscaling everything to 4K and supported SACD & DVD-Audo, so I began using it for everything. Unfortunately, the player recently died and is in the process of being replaced under warranty by Sony, so I am temporarily back to using the Panny BD and Oppo DVD players. So I wouldn't recommend getting rid of all your other players even if you do get the Oppo. You never know when you may need a backup player.
