John Besse
Ok, I'm going to make the plunge into a projector at the end of the week and want some advice on what I should be buying. I will mainly be using the projector for DVDs through a Denon 1600 DVD player. I have digital cable, but will be rarely using it on the projector except for the occasional wrestling and boxing PPV events. I'd say it is going to be about 90% movies and 10% TV.
I am looking heavily into the Epson Home 10 and Home 10+. However, after reading some recent reviews, I think I am leaning more towards the Sanyo PLV-Z1. Either way, I want a native 16:9 projector. The Sanyo offers a resolution of 964x544, and the Epson is at 854x480. Which one would look better on DVDs? I am going to be running the projector on a Da-Lite Perm-Wall Fixed Wall Screen 37.5''(H) x 67''(W) - HDTV Format 77" 16:9 at approx 115" sitting distance from the screen. The room is overall dark, with very minimal ambient light. Which projector is going to handle itself better?
Last, I need some advice on the screen. I am going to buy the Da-Lite 77" 16:9 screen as I mentioned previously. Being that both projectors are LCD based... Which surface would be the best to go with: Da-Mat, High-Contrast Da-Mat, Cinema Vision or High-Contrast Cinema Vision? I have always heard that you should do a white screen with an LCD projector and go grey with DLP projectors. I know the High-Contrast Da-Mat and the High-Contrast Cinema Vision are both grey, so I'm leaning away from those. I'm not too sure about what color the regular Cinema Vision surface is, would someone let me know if it is grey or white?
Well, if anyone has suggestions on what projector to match up with what screen... I'd greatly appreciate the knowledge. Like I said, I want to purchase by the end of the week. Any good feedback would be great help!
