Adam O
- Jul 22, 1999
I am in the planning stages of my Sono based diy sub. I know the following:
Driver: Dayton 15" DVC
TubeSize: 24"
Volume: 280L or so
Amp: Extra plate amp I have (4Ohms, 180w-rms)
Port: width: 6" length: around 25", cant remember exactly
Tuned to: 16.5Hz
As of now I want to cut a rectangle out of the tube, about a third way up the tube, 10" wide by 12" high. Build I small (3-4L Im guessing) enclosure that will be inside the tube and sit in the retangular cutout, I will air proof it etc. The amp will then be mounted on the inside of the tube on this box.
My Question is: Will this box create problems with the way the waves reflect inside the tub, in turn changing the overall clarity, volume, etc of the bass?
As well If you see something that you think I could improve on with the design please let me know.
Thanks Alot.
Adam
TubeSize: 24"
Volume: 280L or so
Tuned to: 16.5Hz
Thanks Alot.
Adam
