Is there a way i can mount a plate amp on to sonotube without it making it look ugly
Discussion in 'Archived Threads 2001-2004' started by Tyler, Jun 24, 2001.
  1. Tyler
    Tyler Stunt Coordinator
    May 8, 2001
    112
    Is there a way i can mount a plate amp on to sono tube with out it making it look ugly & stick out ?
  2. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
    You can build the plate amp it's own little box and then hid it out of the way. That way you have the flexibility to use a component type amp in the future...
    -Jin
    My Theater
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    You can check out what I did. I'm really happy with how it turned out, but you may disaggree.
    http://ht.s5.com/Sonosub.html
    The pictures aren't the greatest but you'll get the idea.
    You could also search HTT for links to Hank Frankenberg's sonosub (not sure if they are still up) from which I got the basic idea for mine. Although his is a perfectly square box.
  4. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Tyler, I mounted mine on the side of my Tempest sonosub (I believe I was the first to do this), and so far no one who has seen it (including a picky interior designer/decorator) has made any remotely negative comment about its appearance. I have the sub placed so the amp is not visible from any HT viewing/listening position, so it's just not a problem. The amp enclosure I built is very shallow (I'm thinking about 3" deep) so it doesn't stick out very far. Could you not turn your sub so that the amp was toward the wall?
