Russell R
- Feb 20, 2000
Hello,
I want to experiment with the setup that I have. It is currently a 142.5L 21.5hz Shiva. What would be the pros and cons of making this setup sealed? I have modeled it in WinISD and notice that the frequency response is not as low, but will it be capable of HT reference levels with a PE250 Plate amp? How low will it play in a small room with the sub corner loaded? Is it safe to assume that it can produce 25hz? Are there other enclosure volumes that may be better?
I have thought about a passive radiator on the top. Can a PR15 be mounted in a horizontal fashion? I am looking at the Shiva EBS PR alignment. This way, there is no cutting of the sonotube that it is currently residing in.
Your thoughts,
Russ
Your thoughts,
Russ
