Carl Hood
Grip
- Jan 15, 2002
Hi,
My Sony projector starts out fine from cold, but after about an hour or so one small portion of the display (around middle top)seems to take on a slight green cast. "Dark" movies with greys are most affected. For example smoke from a chimney in a movie scene will start out blue/grey then as it passes through the affected area of the display the smoke turns sickly green then back to blue/grey. Similarily, off-white walls are tinted with green in the affected area. The rest of the display remains perfect (or at least consistent). It is very noticable on B/W movies. Very annoying.
Might I have a problem with the LCD panels themselves, associated electronics, or maybe excessive heat? It isn't something I have been able to correct via normal user adjustments.Before I return my projector to a service centre, I would really like to get some idea of what might be happening.
Thanks. Carl.
Thanks. Carl.
