Don.l
- Apr 9, 2005
- Don
I am trying to decide on what kind of system I want for remote control of AV components. I could really use some opinions. Let me explain a little. My setup is a follows: HT is app. 11' X 22'. In the back of the HT in a built in shelf unit will be my AV components. I will have a projector ceiling mounted and will be about 14' away from the fron wall. My screen will go up and down and will be motorized. Now, I anticipate the need to be able to control about 8 devices with my remote. I will have 6 AV components and then the projector and also the screen. So, if I go with a IR system I will need to have the eye in the front of the room, and the cable will need to run approximately 35' It will be under the screen and go up the front wall, over the ceiling and all the way back to the box where the emitters will come out. I think that kind of distance isn't good is it? I was looking at the Hot Link system and they have a 25' extension cable for the eye and they don't reccomend going any further.
So, to avoid all of this problem I was considering RF. Anyone use RF? What are the pros and cons of RF.
Thanks for any help anyone can offer.
Don
Don
