Guy Kuo
- Mar 6, 1999
After reading some posts and articles about how helpful it is to mechanically stabilize a speaker to improve the tightness of bass, I wasn't able to find a good source of lead shot to load my SVS subs. The local sporting goods store clerks looked quite astounded when I asked about getting 2,000 pounds of lead shot. Given the volume of the 16-46's, I figured they could hold 2 to 3 thousand lbs of shot each. I didn't mind the ensuing questioning by the FBI, but I was still left without any lead shot to fill my SVS subs. Then I had an inspiration. I remembered some posts from way back in which the author had advocated kitty litter as a substitute for lead shot because it was far cheaper and easier to obtain. Off I went to the grocery store and without any difficulty came back with a trunk full of kitty litter bags. The clerks did comment about me having a bunch of cats, though.
Took a bit of effort to carry them all up the stairs so I'd recommend getting some buddies to help with that "step" of the project.
I tried pouring the kitty litter into the subs through the top grate, but the mesh was too fine. Most of the litter just dropped down the outside and that meant a lot of clean up work on the teddy bear cloth afterwards. Once the grates were removed it was easy to completely fill each sub with kitty litter. (Tip: Wear a dust mask. Even though the litter bag says low dust, there will still be a lot kicked up while you pour it into the sub) Once each was filled, I put the top grating back on. QED.
Both SVS subs are now well base loaded. I think it would be better with the greater mass of lead, but even with just kitty litter I can't move either sub at all. This should give me really "tight" bass, but for some reason no sound seems to come out of them now.
Guy Kuo
Link Removed
[Edited last by Guy Kuo on November 16, 2001 at 08:40 PM]
Guy Kuo
Link Removed
