Hey guys, right now I have a Vizio 42" HDTV and it works great. But the speakers are just "alright". After I built my new computer and put it on here, I got antsy for better sound. I have a set of Bose Companion 2 Series 2 computer speakers from back when I did everything at a desk, but when I hooked them up to the TV (using RCA analog) in such a way that I could control the volume with the TV rather than the speaker dial, the quality was really not much better than the TV speakers. If I put it on "fixed" so the volume was controlled by the speakers, the quality was great. But since I'm playing from a couch and live in a small apartment where noise can become an issue, I'd rather not have to get up to change the volume when things get loud. Anyway, I know electronics, but not much about audio yet. I contacted Vizio to ask their suggestion and they said "The device being connected must be amplified in order to take full advantage of the variable option." (variable being volume control from the TV).
Now here's the deal: I only have about $100 to spend (poor college student, you know). Now I know I won't be able to get killer surround sound or anything like that for that cost, and I'm not trying to. Mostly I'm just looking for something simple (sound bar, dual speaker setup, something like that) that will give me better sound that can be controlled by remote. If it can't be done at all, then hey, I've "survived" on the built in speakers for this long The TV has both optical and analog input, so those are my options (that I know of, of course). So what should I be looking for? Do you guys have any suggestions on a sound setup I could get in my price range? Like I said, to give a reference, when the Bose speakers are on "fixed" (controlled by the dial) they sound great in my little apartment, so they don't have to be massive speakers.
EDIT: May be worth noting that my TV does not have a headphone jack in the back for speakers, only the split red/white RCA jacks. I read somewhere that that makes a difference... but like I said, computers and hardware are my thing, not audio
So what advice can you guys offer?
Thanks!
Thanks!
