BrendanW
Grip
- Jan 27, 2002
I am looking to spend 400 bucks on a reciever. I was thinking about the sony str-de1075. Any advice? suggestions?
Ok, so call Steve at 6th ave ext 511 and tell him your broke but want the 2802 shipped for $529.
Earl,
$529 for the 2802? Is that possible? I paid $625 door to door from 6th Ave. Should I expected even less?
The Sony 1075 for $392 is not a bad choice.
i couldnt disagree more. STAY AWAY from the Sony DE line, as you can do SOOO much better for the money. look at Denon 1802, Onkyo 595, Marantz 5200, and the H/K line. even the Kenwood VR509 outperforms that cheap Sony.
just stay away from the DE line-- you'll be glad you did. good luck!
A glowing endorsement for the Kenwood.
I agree with your recommendation to avoid the Sony DE line but IMO the Kenwood is a fine receiver that should be considered evenly with some of the other receivers mentioned.
Vin
