BryantJones
- Mar 17, 2004
Question on DVD-A...
In order to get the best sound quality, you need to use those 6 analog outputs on the player, correct? What sort of cable do you use for that?
Also, I'm a little confused as to how a DVD player can act as both a video and audio system. Do I connect both a toslink/coaxial and the analog cables to the player? Will the player know to use the toslink when playing movies and the analog when playing DVD-Audio?
Sorry for the onslaught of questions :frowning: I just can't seem to find a clear answer..
Thanks for the help!
