Krzysztof W
Grip
- May 5, 2002
Hi
my present set-up is Def Tech:
BP 2006 Tl mains, CLR2002 center and BP 1.2X rear
(Rotel RSP 1066 and RMB 1075),.
It is great for the room of the size 13 x 15 with 8 ft ceiling. Now I am going to buy a house in which the dedicated HT and music room is of the size 20 x 16 x 9 ceiling and I think that (taking into account shortcomings of my budget) the bet I can do is to add BP 3000 TL asd mains and CLR 3000 as the center moving 2006 to surround and then I can use:
(a) CLR 2002 as the rear 6th channel
or
(b) BP BP 1.2X as 6 and 7th channel.
What do you think?
One of the crazy ideas is to buy Infinity Intermezzo 4.1T as the mains (you can have them for around $4000 and use them as the mains and move BP 2006 to the rear?????
I'd rather go with Def Tech set-up though?
Any comments are welcome?
Krzysztof
P.S. I cannot stretch budget over $4000 thousands so just forget it.
or
What do you think?
Krzysztof
