CaseyLS
- Oct 3, 2002
I just went to the local HT store here in Manhattan and I was able to price some Paradigms for my system I would like to buy around March. I have found the following:
Paradigm CC-70 139.95
Paradigm Phantom 399.95/pair
Cinema 90 199.95/pair.
Total is about $740
First off, when I was reading the paradigm brochure it said in one place all Paradigms are timbre matched while in another it said they are matched with the other speakers in the series. Have any of you mixed and matched series to know if these will sound alright together.
Second, how good are the prices. Should I maybe look some where else or are they good?
My third dilemma concerns a sub woofer. I would like to keep every thing under $1500 if possible. I know this gives me a lot to work with but I don't necessarily have to go all the way to the line. The audio shop has some Def Tech and Paradigm subs so I will be looking at those. Are there any other suggestions? I have considered SVS but since I live in a college dorm and I have to move around quite a bit it would be rather impracticle.
Thanks in advance,
Casey Stoddard
Total is about $740
Thanks in advance,
Casey Stoddard
