MikeTC
- Aug 3, 2000
Hi all,
I just got a new Dell computer with a USB keyboard running under Microsoft XP. I loaded Cat Nip but could not change the properties in Cat Nip software to scan for bar codes.
The Cue Cat I have is the PS/2 plug type. This Cue Cat is supposed to work with a PS/2 keyboard using the "Y" cable atached to the 'Cat. Since my computer has a PS/2 keyboard receptacle, I just plug the Cue Cat into it.
Questions:
1. Does Cat Nip works with XP?
2. Could I plug the Cue cat the open PS/2 keyboard receptacle?
3. Do I need reconfigure the computer? Add drivers, etc...
4. How could I check if the Cue Cat is working which I'm pretty sure it does? It does light-up.
Thanks in advance.
Questions:
Thanks in advance.
