Greg_S_H
I've had this problem for a while now, have ignored it, but would now like to solve it. When I play computer games, and only when I play computer games, my system locks up. And, it's not all games, either. PopCap games, web games, and things like that are fine. It's when I try to play something like Duke Nukem 3D (yes, I still play it) or the Prey demo (problems started before the game was released, so I didn't get it) that I'm locked up.
I first noticed it with Duke3D, so that's what I'll focus on. I'd get about five minutes in, and the system would freeze up, with the sound being played at that moment stuck in a loop. I figured my problems might relate to my sound card, so I disabled it and played the game. I had the same problem, but with the sound off, I could hear a strange sound. It was like the parking sound the hard drive makes when you power down the system normally. If I stopped the game right when that started, I'd be fine. If I kept going, it would do it about three times and lock up. I operated the system with the case open, so I know for sure the sound is coming from the hard drive.
I uninstalled Duke3D and moved it to my external hard drive, but the same problem occurs.
The other day, I was able to play for about 20 minutes. That time, it was the Prey demo, and it ran great for a good deal of play. Then, the frames per second started to get flaky, and it soon locked up. I thought maybe it was a heat problem when it worked that long, but it'll lock up even if I start right when the computer is first powered up for the day. Usually, I can play as much as one minute, or it'll lock up on the menu before the game starts (which seems to rule out an accelerator problem).
Another thing worth mentioning: the other day, after a lock up, my boot time inflated from the usual 30 seconds to minutes. It continued to do this until I did a system restore, which fixed it right away.
So, does it sound like the hard drive is going bad, or maybe the hard drive controller? I'd go out and get a new hard drive immediately if I thought it would work. I'm just worried that it won't.
If I do get a hard drive, my understanding is that they come with software that would allow me to easily image this hard drive onto the new one. Correct? And, if it sounds like my problems are not the physical hard drive but something in my configuration, might I not be imaging my problems right over to the new drive? I've always been reluctant to buy a new hard drive because I was mystified by the process of getting it set up. I visited Maxtor and some other HD vendor sites, and they have easy step-by-step guides and software. I could start from scratch, but I think I only have an OEM installer version of Windows XP.
I'll shut up for now and hope somebody can help. And, hope that I can answer questions to make this clearer if need be.
