Brian Bunge
- Sep 11, 2000
You can find the metal grills at radio shack. But the screw in directly over the driver. In other words, you remove 4 of the driver's mounting screws, place the metal grill over it with the holes aligned, and then screw it into place with the new, longer screws that should come with it.
I hope this helps some!
Brian
Brian
