Checkmate1996
- Jun 8, 1999
- Brad
Folks,
Finally installed my ABS in my wrap around couch after having them sit around in my crawl space for a year. WOW! Best HT upgrade I've done. Forget about buying 15" subwoofers, etc. I don't wake up the kids, I keep my hearing AND I get the enhanced feeling of things really blowing up. It's awesome. Here's a few tips from my little experience:
- Equipment: 4-4 ohm 25x2 ABS.
- Tools/parts: drill, Bits, nuts/bolts, speaker wire, terminals, stapler gun, basic assorment of flat blades.
1) Make sure you mount the bass shakers "firmly". Use either nuts and bolt combo or long wood screws.
2) Use a good stapler gun(craftsman, etc) if necessary when re-installing any seams or fabric.
3) I used an older 50x2 sony receiver for my power source. However, for the sake of simplicity, bulkiness and more power, I will probably upgrade to a standard 100x2 amp. I have the 25 watt bass shakers. However, when ran in series at 8ohmms, they can easily handle the wattage. In my experience, I prefer to run my amps low and have plenty of headroom than cranking them all the way up into distortion land.
4) Tweak the bass level you prefer with several different reference DVD's until you are pretty satisfied with the correct level. Start low and then work up.
5) Finally, make sure you have it tweaked before you show it off to your friends!
