VE Questions/Problems:
Discussion in 'DVD' started by Chad Viro, Mar 7, 2004.
  1. Chad Viro
    Chad Viro Stunt Coordinator
    Mar 1, 2003
    87
    Hello All!
    Well, I finally got my first-ever Home Theater setup this weekend, and I have a few questions. Here are my HT specs:
    Speakers: Axiom M60Ti's, VPN150, QS8's (3 aura bass shakers in series with 100w PartsExpress Amp)
    Receiver: Denon 3803
    DVD Player: Denon 2200
    After running the Video Essentials DVD for the first time (with repeat viewings of some areas I was/is confused about), I have a few questions I am hoping someone could answer. So here goes!
    VIDEO SETUP:
    1. When running the video setup section, do I want to set the contrast/brightness so that the three stripes on the side are 'just' visible? What I got from the video is that the outside line should be engulfed into the background, and I should still see the other two vertical stripes.
    2. When setting up the color using the red/green/blue filters, I am able to get the blue and red filters 'almost' perfect (so that all the blocks are fluid through-out the screen); however, looking through the green filter, it looks horrid! The blocks are OBVIOUSLY not fluid with eachother.
    AUDIO SETUP:
    1. When trying to setup the my speakers/receiver to reference level, the DVD keeps cycling through the speakers. For example, I want to set-up the left speaker using my SPL(weight C, 75db), but when I am trying to make the changes, it changes to the center speaker, then goes to the right speaker, etc. How exactly do I make it stay on one speaker so I can make the necessary changes in my denon surround sound menu?
    2. Do I just want to change the Db values for my speakers? Should I bother to change the distance values for each speaker? I believe they are all still set on default.
    Any help would be great! Thanks!
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    There are some tests to check this- but if your speakers are equal distances from you within a foot or two, no problem. If not, you might try to delay setting - sett 1 ms of delay for each foot closer the speaker is from the rest.
    Check out http://www.dolby.com/tech/co.br.0103.DDFAQ.html#q19
    #19-21
    -Vince
  3. Chad Viro
    Mar 1, 2003
    87
    Thanks for answering a few of my questions, Vince! I am really surprised I have to cycle through them again. I suppose I could put the dvd on repeat for each speaker.
