Craig LeBlanc
- Aug 3, 2000
I'm just about to embark upon my first journey into the land of DIY speaker construction ! Woo! (had to get that out of the way). I'm just looking for some quick advice before I take the plunge.
I picked up one of the Shiva Sub-V kits last summer and just finally getting the free time to put it together. I'm wondering if anyone else has used the designs from the Adire (formerly Avatar) webpage? My choice is between the 85L and 95L designs. I think I've pretty much decided on going with the smaller 85L box because of it's response curve (I listen to audio on my system as well as home theater applications)
As of right now, I will be powering it with my trusty NAD 2200PE amp until I'm satisfied ith the sub's performance...then I will be getting a plate amp. I am trying to plan ahead for that day... should I add a layer of plywood to the back of the box for easy mounting of the plate amp ? or will MDF be able to take screws that will handle 25lbs+ of amp ?
The box construction looks pretty straightforward... I'm just wondering what brands of glue I should be looking for...and maybe some ideas on how to finish the box (right now the #1 candidate is black spraypaint)
