Jack*Mains
- Sep 25, 2002
Hey, Im not really new to DIY, but I've never built a sub before, so I require a little help
I cant spend a lot of money, so I was thinking of getting a Shiva and an Adire AVA250 Plate AMP. The Amp already has a built in crossover, so I dont think I need another one.
Now here comes the hard part. I Need to build the box. The building part doesnt scare me, but there are so many different options im not really sure what to go with.
I was suggested to build a 54L Sealed box, but im not sure if that would give the best results. I listen to music a lot, as well as watch DVDs, so I need something that can handle both well.
I kinda like the idea of having nice clean / crips bass, so the sealed box is probably a good idea, but what size?
Adire website has very good design specs for various sizes of boxes, including the 54L design, and going up to 85L, as well as many vented ones.
Also, im not really sure how to give it a nice black look. I DONT want anything too shiny like the piano finish. The best option would be to make it look like that cheap black plastic crap they make just about all other electronics out of. You know the stuff im talking about! I always found that something you build out of wood / MDF looks a lot better if you simply put some type of a varnish / oil finish on it, but it simply wouldnt blend in with anything downstairs. Pretty much everything I have set up down there is black, including the couch.
Again, thanks for the time and Im really looking forward to doing this. *Also gives me a great excuse to buy some new power tools *
