phillip jones
- Dec 10, 2002
HI,
This probably sounds daft. But, I am going to use the subwoofer out on my amp to feed another amp to drive the subwoofer the second amp(driving the woofer) is a Stero/proligic I know that I need a splitter, But should I split at the sourse side and run two cables or run one cable and split at the destination amp? Will there be any gain to this or is the less cables the best?
thanks
Phillip
thanks
Phillip
