Jerome Grate
- May 23, 1999
I just purchased this t.v. http://www.magnavox.com/index.cfm?ev...=3&product=102
for the family room for daily t.v. watching and as you can see it has the ATSC/OAM tuner. I'm looking to purchase this indoor amplified antenna
http://www.jr.com/JRProductPage.process?Product=4010754
The question I have do you think it will work. I went to CES and saw that based on my zip code there are two channels I can get and that's fine because one is a local channel that has the local news and other HD programming. Should I placed this near a window or in this case it would be the side door to the deck. Will this work or should I look for something outside mounted.
