Hi everyone.
My home SHOULD be complete by Nov 15 and I have afew questions about my prewired system. I have my theater/family room downstairs. The av gear will be in a closet and the rear speakers are in ceilings that I bought from www.htd.com The fronts will be floor standing and a center. The rest of the house has 6 total in ceilings, also from HTD.com with outlets for volume controls. Everything terminates in that downstairs closet.
I do have two seperate receivers, one for my Theater and another older JVC digital receiver. It was leftover from my old theater so I figured I'd reuse it.
Here's my concern...
Aside from the master bedroom, which has two speakers, the others will be single units. There's one in the dining room, one in the upstairs hallway, one in the master bath, one in backyard patio, and the two from the bedroom I mentioned. How can I get my 5.1 receiver to output MONO sound to all speakers? I want the same music from all of them but I fear that they will be playing in stereo when there is only one per area!
Won't the sound split between the speakers connected to right and left channel? I plan to use volume controls and a speaker selector again from HTD.com. I just can't figure how to get the same sound from each of them? I will primarily use the receiver for my iPod and fm stations once in a while.
Thanks!
Thanks!
