Jonathan Dagmar
- Dec 29, 2002
When I first got my home theatre my goal was to get a complete system all at once. I didn't have a lot to spend but I was not willing sacrifice upgradabilty buy buying a HTIAB.
I ended up with a very nice Panasonic 6.1 all digital reciever (SAXR25), and a Panasonic F65 DVD player. Both of those items will be staying until they break, I am very happy with them. The TV I purchased is a JVC i'art 27 inch flatscreen analog set. I am more or less happy with it. it will be replaced by a progressive scan set as soon as I can. Still trying to decide if I should wait for an affordable LCD or just buy the Toshiba direct view I have been looking at.
Anyway, my apologies for rambling. My real question is about speakers, as my current ones are my least loved part of my system. I bought a set of Yamaha Sattelites and sub. They sound ok with most movies, but I do think the sub bottoms out fairly frequently. For music they leave much to be desired, being quite anemic in two channel mode, though a lot better if I use Pro Logic II.
I have more or less decided to buy the following:
Fronts: Athena ASB2 Bookshelf speakers
( http://www.futureshop.ca/catalog/pro...=&newdeptid=10 )
Left and right surrounds: Either ASB2's or ASB1. Leaning towards the cheaper ASB1's, is this wise?
Center: Athena ASC-1 {http://www.futureshop.ca/catalog/pro...=&newdeptid=10 }
Now for the center surround I am not sure what to do. I would prefer to put another ASB2 or ASB1 back there, but I don't know if I can buy a single, so I would have to buy two and just set one aside. The alternative is to use another ASC-1 center for the center surround, but it seems like overkill to use a center channel cpeaker for the surround speaker that will probably see the least use of all the speakers. I am also thinking that it may not be such a bad thing to have that extra speaker around in case I ever have a space large enough that splitting the center surround between two speaker made sense.
As for the subwoofer, this is where it gets quite tricky for me. I haven't really known what to look for. I have considred both of the following:
Athena AS-P400 { http://www.futureshop.ca/catalog/pro...=&newdeptid=10 }
Velodyne CHT-10 {http://www.futureshop.ca/catalog/pro...=&newdeptid=10 }
Neither of these subs go down to 20hz, should this be a concern? Please be aware that if you suggest other models they should be easilly available, preferably at best buy as I work there and get a discount.
